Leniad's avatar
Leniad
Netgear Orbi Voice RBS40V I can't Set up with a router that is not an Orbi
My Netgear Orbi Voice  RBS40V cannot be configured as an Extender
following the guide to configure my Orbi voice as an extender when I don't have an Orbi router:
https://www.downloads.netgear.com/files/GDC/RBS40V-200/RBS40V-200_QSG_EN.pdf?_ga=2.77862166.32177553.1690885087-2033231847.1669722877
I have downloaded the app, I have reset the device in factory mode (also has the latest Firmware) and in the part where it says:
"Locate and connect to the Orbi Voice WiFi network called NETGEAR_EXT"
well it does not show, instead I see the the SSID ORBI44 configuration itself is called ORBI4 which obviously matches with the factory default SSID sticker that I can see below my OrbiVoice but even though I connect to that SSID, the app by default only searches for network NETGEAR_EXT, which is why it doesn't let me configure it at all.
Has anyone had the same case and been able to solve it? or  Does anyone know how to configure it with a non-Netgear router?
Thanks in advance
      • Leniad's avatar
        Leniad
        Hi, thanks for your answer.
        My model is RBS40V Is there a way to force it to be in Ext mode or for be this model it will not allow?
        thanks
    • Leniad's avatar
      Leniad
      Hi,  First thanks for your answer, well I follow your link and I have tried to manually load the firmware ext mode but it fails, it does not allow it to be loaded, could it be because my model is not RBS40V-200 is only RBS40V ?
      Is there a way to force it to be in Ext mode?
      Thanks
  • Guys! CrimpOn, FURRYe38
    First many thanks for your assistance and good news! I found the solution of how you set up in extender mode the RBS40V (without -200 model or Ver. 1), the solution is in this link:
    "How do I setup my Orbi Voice RBS40V in Extender Mode?"
    https://kb.netgear.com/000061427/How-do-I-setup-my-Orbi-Voice-RBS40V-in-Extender-Mode
    the trick is the Sync button and the SSID show the EXTENDER_EXT, so now my RBS40V is working with another router.
    Thanks
    • Leniad's avatar
      Leniad
      Hello,
      I have a  RBS40V (not  RBS40V-200) but reading your thread looks like you have the same model like me (RBS40V) and you talk about that your device was in extender mode, How were you able to make it in extender mode? because I understand that only the model RBS40V-200 allows it to be both, extender and orbi mode.
      Thanks
    • CrimpOn's avatar
      CrimpOn
      You did this, and it worked?
      Would have been a lot easier if this had been mentioned in the Product Data Sheet, Installation Guide, or the User Manual.
      • Leniad's avatar
        Leniad
        hi,
        If it works wonderfully, I was already disappointed by the simple fact of wasting a great product, but when I did one last search on Google,voilà ! the answer!!, and exactly what you say, why the user´s manual does not contemplate that and you end up finding it in a KB, well today something new to learn, let's share wisdom 😉
