Appleuser2000's avatar
Apr 03, 2020
Orbi dropping connections
I got new Orbi+1 Satellite and updated to latest to firmware after reading rave reviews. Unfortunately just couple of days in the Orbi Wifi signal disappears and I lose connection, the solution is to shutdown the device and restart. A less than pleasant expereince for a $400 brand new device.
For now I have shutdown MU-MIMO, Beamforming, Fast Roaming, and Daisy Chain Topolgy and drop 5GHz power to 75%. I read about Orbi dropout but that was supposedly fixed in firmware updates a couple of years ago. Whats the point of paying for these features if we are going to have not to use them to keep a stable connection?
My second issue is that the satellite will lose its connection with the main unit on reboot and have to re-sync each time the power is shut off.
    • Appleuser2000's avatar
      Appleuser2000
      Guide
      Retired_Member wrote:
      firmware?
      the latest as I have mentioned 2.5.1.8
      • Retired_Member's avatar
        Retired_Member
        firmware?
        The are numerous problems with that one
        go to download and look for a earlier version
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
    Factory reset and setup from scratch. https://www.youtube.com/watch?v=cMw4ePACgc4
    https://www.howtogeek.com/434350/how-to-factory-reset-a-router/
      Retired_Member
      :smileysad:
  • Appleuser2000 If the Orbi is brand new I recommend you to return it if possible. The are a lot lf problems with previous fw versions also. I had similar problems on fwV2.3.5.30 that could not be configured away. There are countless similar topics in the community topic history and no clear solutions.
    Bad software design, substandard routines for testing and release of new softwares makes Orbi totally unreliable and now, in the end of its product life cycle, it will probably never reach a stable state.
    Spare your time, money and efforts and spend it on something that pays back instead :thumbsup:.
      Retired_Member
      Your best option is to stop performing manual fw updates.  I too saw the numerous posts about 2.3.5.30.   Then several months later it was pushed to me (oct 19).  Problems appear to be gone.  Yet the version numbering remained the same.  Leads one to believe that all those who did the manual updates were actually beta testers.
      so again stop performing manual updates less you want join join the beta testers club and live on the edge.  You've been warned.     FYI.   All router makers have their share of fw problems.
      • BigRune's avatar
        BigRune
        Apprentice
        Well I purchased Orbi january '20 and it upgraded on setup. Suddenly starting to malfunction 3weeks in...
        I dont understand the 'beta' discussion? Noone should be beta tester unless they participate in a beta program.
        Orbi is just an old flawed product and I guess Netgear thinks all customers are potential beta testers.
    • What other maker do you suggest for mesh system? Netgear Orbi is contantly getting praised and the product is a flagship, they released a new Wifi 6 Orbis. Its been out for sometime but there has been no real advances in technology really to make it old.
      There is Ubiquiti but you have to wire the access points.
      • BigRune's avatar
        BigRune
        Apprentice
        Do your own research, with your own requirements 😀. Look into forums and communities. Do not pay too much attention to all sponsored router reviews flooding internet.
        Lack of research made me buy Netgear Orbi (ouch! :smileylol:). My following research online and IRL led me to a Ubiquiti Unifi solution. Unifi is a kind of SOHO/PROsumer networking with a lot of flexibility. I liked the new "Dream Machine" that made the entry to Unifi simple and decided to give it a try.
        The Ubiquiri Unifi Dream Machine combines all standalone Unifi network parts needed. Actually delivering better performance to a lower price than buing separate Unifi parts, (Gateway, Cloud key, switch, access point).
        UDM has a built in AP ("wired") that can connect additional Unifi AP wireless. I have not studied wireless downlinks as I have a Wired NanoHD access point on 2nd floor (works great 👍 ). Read more here : https://help.ubnt.com/hc/en-us/articles/115002262328-UniFi-Configuring-Wireless-Uplink
