Maroman's avatar
Maroman
Guide
Mar 26, 2019
Orbi Traffic meter and Daylight savings
The traffic meter feature in the Orbi only works if you disable daylight savings time. That works but for some reason daylight savings becomes enabled again then the traffic meter stops working again.
I went through a full factory reset of the router yesterday. Has anyone come up with a solution?
  • Interesting observation....  if accurate... have you validated off of another installation or just yours?
    FURRYe38  have you seen this?
  • FURRYe38's avatar
    Maroman
    So when TM stop working, what are you not seeing?
    I have not seen this, however I don't use TM. Something you can confirm Chuck_M ?
    I'll check on this with one of my NG routers I have online currently.
  • CrimpOn's avatar
    CrimpOn
    Oh, my!  I have always had Traffic Meter turned on with "No limit" and check it every couple of months just for entertainment.  Sure enough, when I checked today it was turned off during the firmware update.  Enabled Traffic Meter and after waiting a bit, "Today" remains at zero.  (I can understand the recent firmware update wiping out past records.)
    Did  not turn off Daylight Saving Time.
    • Maroman's avatar
      Maroman
      Guide
      I didn’t realize there was a new firmware available. I just updated yesterday so I’ll try it out and see if the issue is resolved.
      Thanks.
      • FURRYe38's avatar
        Ok keep us posted. If the new FW doesn't resolve, lets contact NG support about it.
        Thanks.
  • FURRYe38's avatar
    NG seems to be aware of this. Hopefully NG will get this fixed soon or in the next FW roll out. Please be patient.
