dg_sticks's avatar
Dec 22, 2016
Orbi Wired Speeds Unacceptably Slow - Wifi Not Impacted - QoS Issues?
Ever since I have received my Orbi, I have been plauged with wired speed connection issues. My wired connection speed continues to be throttled from 10-20Mbps no matter what steps I take. My wireless speeds across all devices are not impacted at all and get a steady 120-145mbps on every device I can run a speed test on. I run Fast.com, Ookla, and Google's speedtest. Ironically, the Orbi speedtest in the QoS section shows a steady 140-150mbps when running. I have done the following steps to troubleshoot this issue:
- Changed wired device I am testing. I have tested 2 laptops (one Toshiba, one Macbook Pro) and my desktop (specs below)
- Changed modems (Motorola SB6180 and another from when the Cox tech came out)
- Replaced all ethernet cords with new cords from a different source (running from the modem to the Orbi base station, then base station to wired device)
- Updated my ethernet drivers (tried various versions, old and new, on both the Toshiba laptop and my desktop)
- Factory reset my Orbi 6 times (using both software reset in UI and the paperclip method; twice on all three firmware Netgear has released since I received the Orbi)
- Turned off MU-MIMO, Beamforming, WMM QoS, all at different times and in different orders
- After running the first Orbi speedtest in the QoS section (after the 2nd firware update added it), I have applied AND not applied the Dynamic QoS prompt (Applying the setting gives me a slight boost in speed about 5mpbs)
This is not my first go around with any sort of home networking, but this is definitely the most frustrating. I have never seen a router throttle wired speeds like this and it makes no sense to me why. The QoS page is sorely lacking of any possible information. How do I know it is turned on? Why does the Dynamic QoS prompt only come up a single time and never again? Where are the options to apply QoS to certain IPs/devices?
At this point in time, I am 99.9% certain all my problems are stemming from the QoS settings of this router, which are apparently insanely aggressive for wired connections. I would love to hear from anyone that either has experienced these issues or has some sort of new idea to troublshoot. If any Netgear reps are reading, I would truly like to hear from you as what else I can provide in order to get this situated. I want to love the Orbi, but having slow wired speeds is absolutely unacceptable for my day to day experience. Please help me!
My desktop specs:
CPU: Intel Xeon E3-1231 v3
Motherboard: ASUS H97I-PLUS (BIOS version 2704)
RAM: 16GB DD3
GPU: EVGA GTX 1070 SC ACX 3.0
OS: Windows 10 (1607 with latest updates)
