jimmauro
Sep 13, 2022Aspirant
RBR50 randomly reboots
My RBR50 Router, connected to my AT&T BGW210 (AT&T Fiber), has been randomly rebooting about twice a week.
Nothing in the logs.
No indication of anything from the BGW210 side.
We simply notice that we lost WiFi, and see the white pulsing LEDs on the RBR50 - it's rebooting.
Firmware is currently 2.7.3.22.
This obviously induces a major disruption in my work.
Thanks
Jim
- jimmauroAspirant
Yes:
[Initialized, firmware version: V2.7.3.22] Tuesday, September 13, 2022 08:26:46
Well fudge. This is not a common problem with the RBR50 model. I can think of some obvious steps:
- Guarantee that power is not being interrupted (even too briefly for people to notice) by powering the RBR50 with a small UPS.
- Test that the power supply cord is not damaged by 'wiggling' the cord to see if that causes the router to reboot.
- Update the firmware to the latest release: https://www.netgear.com/support/product/RBR50.aspx#download
My RBR50 routinely stays up for months at a time (until I deliberately mess with it or Edison cuts power for repairs).
- jimmauroAspirant
And several "attack" messages in the log, which I assume (perhaps incorrectly) is typical...
[DoS Attack: TCP/UDP Echo] from source: 89.248.163.150, port 52401, Tuesday, September 13, 2022 14:17:18
[DoS Attack: SYN/ACK Scan] from source: 74.91.112.166, port 8080, Tuesday, September 13, 2022 12:26:30
[DoS Attack: SYN/ACK Scan] from source: 222.92.255.14, port 39602, Tuesday, September 13, 2022 12:18:13
[DoS Attack: TCP/UDP Echo] from source: 71.6.135.131, port 27221, Tuesday, September 13, 2022 11:55:51
[DoS Attack: SYN/ACK Scan] from source: 91.218.213.49, port 8000, Tuesday, September 13, 2022 11:23:23
[DoS Attack: ACK Scan] from source: 52.96.79.37, port 8678, Tuesday, September 13, 2022 11:00:24
[DoS Attack: RST Scan] from source: 199.187.116.122, port 30106, Tuesday, September 13, 2022 10:53:09
[DoS Attack: ACK Scan] from source: 52.96.79.82, port 443, Tuesday, September 13, 2022 10:18:22- CrimpOnGuru - Experienced User
Your assumption is correct.
I have kept every log file for over three years, and every single day there are many (many) such log entries. My feeling is that this is a normal and unavoidable consequence of connecting to the internet.
For example, by having a telephone, I now get at least 20 calls every day wanting to "Press 1 to learn if my house qualifies for drought tolerant landscape, solar panels, double pane windows. Press 9 to be removed from the list." By having a mailbox, I get catalogs and advertisements that I never asked for. By connecting to the internet, I now have every pimply-faced teenager in the world wondering if there are any ports open on my router.
There is an option to turn off the feature of logging these (possible) attack scans.
- KevinLiTNETGEAR Moderator
Hello jimmauro,
Welcome to the NETGEAR Community!
I understand that you are having reboot issues with your RBR50 on firmware version 2.7.3.22.
Please update your RBR50 firmware to version 2.7.4.24 then check your RBR50 for reboots.
Please navigate to the link below for the most updated firmware for your RBR50:
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Best,
Kevin
Community Team- jimmauroAspirant
Thanks. I updated both my RBS50 Satellites and the RBR50 router with the latest firmware this morning.
As the reboots have been random, I need to wait at least 2 weeks before I start to feel warm and fuzzy that the issue is resolved.
I will post an update here either way.
Best
Jim
You might give Voxels 3rd party FW a try as well. If the reboot still happens even with this FW, then there is either a HW problem or a environment problem.
Good luck.
- jimmauroAspirant
Well, it was close, but no cigar.
I did the firmware update on 9/17. The router rebooted yesterday (9/29).
So there's still a problem with my RBR50 randomly rebooting. Here's the log entry:
[Initialized, firmware version: V2.7.4.24] Thursday, September 29, 2022 17:11:04My next move is to remove the Orbi gear, re-enable WiFi on the AT&T BGW210 modem, and plug a couple WiFi
extenders in on the 2nd and 3rd floor.
Very disappointing. The Netgear Orbi devices are relatively expensive. I paid almost $400 for the router and
2 satellites just over a year ago.
Appreciate everyone's input.
Jim
