ivanpang
Jun 17, 2017Follower
Samsung Galaxy S8 not working on Orbi RBR40
Galaxy S8 keeps connecting Orbi wifi with message "internet may not be available" then logging off again but all other devices including iOs, TV and laptop can connect quite well. I'm using 1000M internet connection in Hong Kong with maximum speed around 450-550M in my other router - ASUS RT-AC68U. This Orbi only runs around 250M something. I'm very disappointed.
- johnnyrook82Initiate
I have noticed with the recent firmware update my Galaxy S8 will randomly lose internet access. The phone maintains a strong connection, however loses all internet access for a few seconds and will then reconnect. I have tried assigning a static IP address, as well as changing the DNS to 8.8.8.8 and 8.8.4.4 - all with no change. My wifes Galaxy S7 and all other devices on my network don't exhibit this behavior. Both my router and my phone are running the most up to date firmwares. Happy to provide further details to get this fixed.
- Dustin278ApprenticeSame my S8 had disconnected in the past 10 days very often..
- mkenny28Apprentice
I reset/rebooted/resynced my Orbi Router and Every satellite again last night and my connections issues (even on my S8) seem to be gone. This is the third time I have done it so maybe one of the satellites was holding onto some cache or something? No clue but I am going to test all day to see if the connection issue comes back.
Be interesting to hear if that actually works. I reset the main router but not the sats. Will have to try that later.
climbingx wrote:Be interesting to hear if that actually works. I reset the main router but not the sats. Will have to try that later.
Well I didn't physically reset the satellites. I just powered my whole system off and then Started router and satellites back up in order from closest to router to furthest. So turn router on, then closest sat, then next one, etc.
- ElMagoFrankAspirant
Add me to the list having problems with constant dropping of internet connection on a Galaxy S8+ (WiFi connected with exclamation point). I am on the latest firmware for both the Orbi (1.12.0.18) and my T-Mobile S8+. It only seems to happen when I am connected to one particular satellite in my house. Disabling WiFi and re-enabling it on the phone seems to allow it to have internet access for a brief second. Other devices connected to the satellite work without issue.
I seemed to have fixed my dropping connection on my S8 by resetting each satellite with a paperclip then re-syncing the satellite to the router.. I will keep you posted.
- vargoose84Initiate
I don't have any satellites and am on v.18. I've full factory resets of the router to no avail. Hopefully this can be fixed soon, it's annoying.
- Brianw108Initiate
Just registering my issue along with the others. I have tried factory resets on both the Galaxy S8's and the Orbi to no avail. The temporary fix of using the guest network has helped the issue, please let us know when it has been fixed, thanks!
- ngfinleyInitiate
I'm also having the same issue. It's been almost 2 months since the first report and there is still no official answer from Netgear on this topic. Unbelievable.
- Yup. After that inane response I got from that level 2 tech, I sent mine back. This is way too expensive a product to have that sort of support.
- pdog881AspirantHow do I return this POS when out of return window?
- Hokie06Initiate
I am also having this exact same issue with 2 Samsung Galaxy phones and an Orbi Router. Wi-Fi constantly drops. I do not have the same problem with my Apple phone. Please fix this issue. It is very annoying.
- nicksterlingInitiateI just recently upgraded to the S8 and I'm also experiencing this issue. I'm using the guest wifi trick and that's working so far but this is definitely a frustrating bug. I'm hoping to see a resolution to this soon.
- Same problem with my S8+! Unfortunately the guest network "workaround" does not allow me to control/access my numerous wifi-connected devices.
Netgear Admin: Has Samsung told you they are working on a fix on their end, or are you working on a fix on your end?- drot84Initiate
Also started experiencing the wifi issue after updating my Verizon Galaxy S8 plus to the new firmware around July 27. Not a happy camper! At least I'm on unlimited data.
Also, lwestfall as someone mentioned earlier, the Orbi guest wifi CAN access at least some things on the main network if you check "Allow guests to see each other and access my local network" - I just started trying the guest network and was able to access a Roku on the main network. Hopefully that helps you.
My Sprint S8 Plus received a firmware update this morning and so far it appears to have fixed my disconnect issues. I will test further throughout the day but Samsung may have fixed Netgear's issue for them.
- Retired_Member
Since the same problem exists for many other devices (iOS, Surface, etc), it's not likely.
@TXGunLover wrote:Since the same problem exists for many other devices (iOS, Surface, etc), it's not likely.
It could be very likely. Samsung's forum has a thread filled with Orbi users who have the disconnect issue. Reboots and resets fixed my issues with all my other devices (iOS, Surface, etc) but my S8 Plus was the last device that just kept disconneting no matter what. I have been testing it for several hours all over my property and I have not had one single disconnect. If this holds I will chalk it up to Samsung fixing what Netgear broke with their device.
- freimanGuide
RBK53 V1.12.0.18 Android
I also have been having trouble however my issue is only with 1 of 2 Samsung Galaxy 8. it gives the same message everyone else has internet may not be available. I thought it was my phone brought it to Samsung and they replaced the mother board. brought it home had the same issue. switched wifi to my providers wifi and have not had the issue.
I also have noticed that the 5g network is no longer available .
Does anyone know when a fix will be developed and why this problem may be affecting only 1 of 2 samsung
- freimanGuide
i checked another feed which stated that the latest version of the firmware was to solve the problem. checked I had that firmware. followed directions to reset my ORBI to the factory setting worked for about 5 minutes and then had the same problem so the new firmware did not solve the problem
- AdsmgmtTutor
I just update the router to newest firmware (v1.12.0.20) and the samsung s8 plus still dropped. I guess gotta do guest network a little bit longer.
Adsmgmt wrote:I just update the router to newest firmware (v1.12.0.20) and the samsung s8 plus still dropped. I guess gotta do guest network a little bit longer.
Sprint sent my S8 Plus an update yesterday and my phone has been rock solid throughout my network since (not one drop). I am running an RBR50, 2 RBS50s, and an RBW30 on my property, nothing in AP Mode on firmware V1.12.0.18 (the RBW30 runs on V1.12.0.4 which seems to be for the wall plug only)
Sprint's info on the update makes no mention of Wifi fixes in particular but here is the info:
Samsung - Galaxy S8+ (SM-G955U)
Software Version:G955USQU1AQGL
Release Date: 8/14/2017
Method: Available OTA + OEM Tool
Fixes:
A software update can include, but is not limited to:
- The security of your device has been improved.- Wi-Fi Calling is now Calling Plus with new & improved features.
- Enhanced Messaging new features.
- Device stability improvements, bug fixes.
- New and / or enhanced features.
- Further improvements to performance.
