saleh86's avatar
saleh86
Guide
Mar 17, 2023
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably
- A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlike my previous router m5, which lasts for more than 12 hours
Some options only work by restarting the router several times, such as wifi 160mhz and changing the network port speed to 10/100/1000mbps.
The ethernet connection does not work with the xbox series
I have NTGX65 update 10.04.16.00
I watched several routers with the latest NTGX65 10.04.23.00 update
I hope to fix the problems and send an update that solves them
