mondofresh's avatar
mondofresh
Initiate
Apr 30, 2018
Problem with LB1120
My LB1120 on Verizon has been working fine for the past 3 months. Last week the unit stopped working.
Here is what I'm seeing:
Solid amber power light
The green signal strength bars are lit as follows: on, off, on, off, on
When I plug my laptop into the unit directly I'm getting a 192.168.225.* address. I am unable to connect to the 192.168.5.1 management interface. I attempted to factory reset by holding down reset button for 5 seconds and nothing happened. No factory reset seems to have happened.
Anyone have any ideas?
    • mondofresh's avatar
      mondofresh
      Initiate
      Physical reset:
      I have tried the "press reset for 5-seconds" and there is no resultant reset or status change. Lights continue to be lit as described in original post.
      I have tried holding reset button for over 60 seconds.
      I've tried press/hold during power cycle
      When cabled directly to ethernet port with laptop, I am unable to get to 192.168.5.1. In fact, I seem to be picking up a 192.168.225.* address. Obviously I'm not able to get to default 192.168.5.1. I am, however, able to ping address 192.168.225.1. This IP doesn't seem to serve up the management UI.
      So...it seems like this device is bricked. I can find no documentation that describes the solid amber and every other signal light illuminated condition.
      • JasonN's avatar
        JasonN
        NETGEAR Employee Retired
        Hi mondofresh,
        I will PM for further assistance. :]
        - Jason N
  • This seems to be a common issue for based the this thread. I recently had a modem that I purchased about a year ago exhibit teh same behavior. At first I thought it was other issues but today narrowed down the issue to the modem. I have default configuratin where the modem assigns DHCP ddresses to connected hostsin teh range 192.168.5.2 to 192.168.5.9. Thsi has been working well since the last year  when i deployed it. Today when I connected the laptop to the modem, it assigned an IP in the range 192.168.225.x and teh default gateway was 192.168.225.1. I then assgned a static ip to my laptop with address 192.168.5.9 and coudlnot access the configuration page 192.168.5.1.
    The PWR LED was solid amber and all teh otehr lEDS were on. I tried to factory reset them modem via teh swicth but it did not work.
    I also went ahead and powerd down teh modem, removed teh sim card and powered it without it and still coudl not access and same PWR LED status. I then powerd down and inserted back the sim card one more time and still no lukc. I tried the factory reset by holding down the switch for as long as I could and still no luck.
    Does anybody have any luck or resolution on this issue? Can I make a conclusion that its possibly a hardware issue that just fails excatly afetr one year of use within the warranty period?
    Thanks,
    E
    • erik90's avatar
      erik90
      Hello all,
      I know this is an old thread but I am looking for some answers or resolutions from anyone who might have experienced the same issue. After trying all the diagnostics and factory resets as suggested in this forum I still was not able to resolve the problem.
      Thanks,
      E
      • johndlewis's avatar
        johndlewis
        I have the same problem, it looks as though mine did a firmware update on its own and that's what sent it spiraling.  A factory reset worked for a few minutes, then back to the solid amber light.  This product let me down in a profound way, and at a remote site that's hard to get to...never again.
  • Just thought I would mention that as of July 28 2020 Verizon will not recognize the LB1120 as a certified device. At that time service will be terminated.
