get2guy
May 14, 2016Aspirant
Another SFP brand for Netgear SW
Hi All, I'm thinking on purchasing 4X GSM7248-200NAS and connect them to one another on an existing LC cables that run's between our buildings. Which SFP modules can i use with this netgear? ...
get2guy
May 15, 2016Aspirant
DaneA,
You have suggested 1Gb SFP modules.
My goal is to connect the switches to one another at 10Gb.
I couldnt find the proper documentation regarding 10Gb SFP's.
I found this SFP http://www.netgear.com/business/products/switches/modules-accessories/axm761.aspx?cid=gwmng
But its 300 $ in amazon while a similar SFP from Cisco is only 60 $
Does netgear offers a reasonbly priced module?
DaneA
May 16, 2016NETGEAR Employee Retired
Hi get2guy,
The AXM761 is not compatible with the GSM7248v2. If you want to use the AXM761, you will need to use either of these NETGEAR Switch model series below:
Refer on this table below:
About the prices, I suggest you to inquire to any of the NETGEAR Authorized Resellers in your country.
DaneA
NETGEAR Community Team
