sohanshop
Nov 30, 2015Aspirant
Can't print after installing ProSafe 16-Port Switch
I installed a new switch yesterday. All my peripherals work fine except the Fiery RIP. I can't ping it or print to it. I have Command Central and that won't link either. As far as I know, the switch ...
sohanshop
Dec 02, 2015Aspirant
Went back to original config and we're up and printing. Bummer is I purchased this back in August even though I didn't crack open the box until Sunday.
Jedi_Exile
Dec 07, 2015NETGEAR Expert
Since it is switch and the other older item you had working was router,... do a simple thing. Connect 1 port on the new switch to 1 port on the LAn of the old router. Now hookup up PC and see if everything works the same.. if it does.. move everything on the LAN ports of the router to the switch and you are good to go. See the diagram before.
