boe
Dec 10, 2025Luminary
Can't reset switch to factory defaults
Hello, I've tried the paperclip that usually works for my other switches. Tried 3 seconds, 5 seconds, 8 seconds, 15 seconds, 25 seconds over and over - still doesn't reset. I hooked up a usb...
- Dec 13, 2025
For anyone wondering - I found the solution!!!
UmerKhalid
Dec 13, 2025Aspirant
On Netgear M4300, the reset button must be held while powering on the switch. Also check console settings: 115200, 8-N-1, and make sure you’re using the correct console cable/port.
