NetworkAdmin
Sep 01, 2012Aspirant
Can't Unstack GSM7252PS / GSM7228PS
I'm having several issues, but they may all be related to stacking... I successfully stacked two GSM7252PS and one GSM7228PS using the front SFP ports and Infiniband cables. Prior to stacking the ...
NetworkAdmin
adit wrote: Did you factory default it? Should fix it.
I didn't try a factory reset because I don't want to lose my port configurations, PoE settings, VLANs, PVIDs, LAG, etc., and if things are so messed up right now that PoE and LAGs and Stacking are messed up, won't I just reintroduce the problems if I restore from a backed up config ?
But this begs a larger question... Once you stack these switches, is a factory reset the only way to remove a switch(es) from the stack ? (or should they be able to return themselves to an unstacked configuration on their own, when they reboot and see that they are no longer stacked ?)
