NetworkAdmin
Sep 01, 2012Aspirant
Can't Unstack GSM7252PS / GSM7228PS
I'm having several issues, but they may all be related to stacking... I successfully stacked two GSM7252PS and one GSM7228PS using the front SFP ports and Infiniband cables. Prior to stacking the ...
NetworkAdmin
Sep 26, 2012Aspirant
Thought I would post a follow-up to my "Can't Unstack" thread.
The trick seems to be that you can DELETE a switch from the stack (System>Stacking>Advanced>Stack Configuration) if you boot the stack manager switch WITHOUT the switch(es) you want to delete connected to the stack manager, and the switch(es) status in the stack shows as "not present". If the switch(es) you want to delete are active members of the stack, you can't delete them.
Hope that helps someone !
