richard-gray
Sep 18, 2019Aspirant
Change port from Ethernet to stacking ports
Hi, I'm trying to join a xsm7224s prosafe into an existing xsm7224s to create a new stack, without resetting or rebooting the existing switch. They are both at the same version:- Software Version.9...
- Sep 18, 2019
a) show stack-port should show which ports can be configured as Stack/Ethernet mode, the current configured and operational mode. Unfortunately in order to switch between each mode, the switch must be rebooted. I remember this was necessary on all stackable switches from Netgear back to the GSM7328FS which was the oldest model I ever had in my hands (8.0 or so, definitely also based on VxWorks.). Same applies to the current M4300's.
Unfortunately a show running-config doesn't give you this information, I think since it's not even part of the startup-config either, you have to work with the commands show stack-port and stack-port unit/slot/port [ethernet|stack].b) Although it shouldn't interfere when a port is configured to stacking mode: 'no vlan participation include 1' should do the trick
c) I don't think so. Once the ports on each side are in stack mode you can join them
together using either the CLI or the GUI.
d) Because you like solving problems are are to honest for a life as jetsetter? ;-)
msi
Sep 18, 2019Luminary
richard-gray
Hi again! Just for completeness in case anyone else is having the problem on :-
That doesn't work. it seems that once you have added any vlan info into it the port will always add a vlan to it.
given that this isn't the cause of my [CENSORED] problem I haven't dug in any further to it.
Don't worry you still keep your KUDOS and the Soloution tag... :)
- msiSep 18, 2019Luminary
Thanks for updating - alright, I wrote the statement on b) based on me quick-checking the CLI guide but not an actual checking a config so it was out of my head. You should use 'vlan participation exclude 1' instead. I think there might be another possibility which would make VLAN 1 not being automatically added to each port by default.
You can then see the actually aprticipating VLANs:
(sw-as-v2-01) #show vlan port 1/0/1 [...] Forbidden VLANS: VLAN Name ---- --------------------------------- 1 default
Unfortunately I can't update the first post anymore so that nobody does erroneous copy-pasting. :-\
