dehidding
Oct 24, 2018Follower
Changing switches in a stack - GS748TPS+GS724TPS -> GS748TPS+GS748TPS
I have a need to change out a switch in a stack made up of a GS748TPS + GS724TPS. The new configuration would be a GS748TPS + GS748TPS. Any recommendations on the best way to accomplish this ch...
DaneA
Oct 29, 2018NETGEAR Employee Retired
Hi dehidding,
Welcome to the community! :)
Is it possible to retain the stack configuration through the change? Should I assume that I'll need to restore the configuration after the change? Will port 1 of switch 2 retain it's settings, even though the total number of ports will be changing?
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, the stack configuration cannot be saved in configuration. The stack likely needs to be broken to add a new switch.
Am I correct in assuming that all switches will need to be at the same firmware level?
Yes, make sure that all switches have the same firmware version before doing a stack configuration.
DaneA
NETGEAR Community Team
- DaneANov 07, 2018NETGEAR Employee Retired
Just want to follow-up on this. Let us know if you have further inquiries.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
