Kerberos07
Oct 05, 2017Follower
DHCP Relay Problem
Hi,
I installed Netgear M7300-24XF switch as a Backbone and I established 5 VLAN connections to this switch. VLANs are running smoothly. I set DHCP Relay to the Windows Server 2012 DHCP server.
The issue is; while acquiring IPs across the VLANs, windows PCs and mobile devices are getting IP address but Linux & Mac OS devices do not get any IP address automatically. However, I can set IPs manually on Linux & Mac OS devices.
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi Kerberos07,
Welcome to our community!
I suggest you to open a chat / case online on NETGEAR support so that we can take advantage of your free support. Most likely, the clients are the one requesting an IP from the DHCP server.
- May 22, 2011Retired_Member
