Gamehendge
Mar 24, 2016Aspirant
Factory Reset FS750 48port
I cannot get access to the web gui to perform a factory reset of the switch and the Smartwizard Discovery tool doesnt see the swtich. The switch has a reset button but that is to just reset to port,...
- Mar 24, 2016
Hello Gamehendge,
Welcome to the community!
Is the the older modular version or the newer FS750T2? The older FS750 does not seem to be supported by the SmartWizard Discovery tool. One way to access the UI is to find the IP address, you should be able to see it on your router's IP table.
Thanks,
JohnRo
Mar 24, 2016NETGEAR Employee Retired
Hello Gamehendge,
Thanks,
Gamehendge
Mar 25, 2016Aspirant
It is the older version. Route print gave me what i needed, thanks for the info.
John
