MarceloTorres
Mar 23, 2018Follower
Factory reset GSM7328Sv2h1
Hi all, I'm teacher in a Computer Techinical School. We use a GSM7328Sv2h1 management switch model. At a moment I'm the Network Manager. Well, the old Network Manager was fired and took the swit...
DaneA
Mar 26, 2018NETGEAR Employee Retired
Hi MarceloTorres,
Welcome to the community! :)
Kindly access and follow the steps indicated on the article below:
How do I recover the password for my managed Layer 2 and Layer 3 switch?
As you will notice in the image on step #3, it shows that option # 6 is for Erase Current Configuration. After you have successfully recovered the password of the GSM7328Sv2h1 switch, I suggest you to check first its current configuration and if you're decided to start from scratch then proceed with erasing the current configuration of the switch.
DaneA
NETGEAR Community Team
- DaneAApr 01, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate hyour feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
