Machtl
Apr 01, 2016Aspirant
GS105Ev2 turn off EEE?
Hi,
we're currently searching for a small 5 port gigabit switch
were it is possible to turn off all the EEE settings, etc. so, no
Energy Efficient Ethernet stuff or Short Range etc.
Is this possible with
GS105Ev2 Firmware Version 1.4.0.6
Thx!
With best regards,
Martin Lang
- MachtlAspirant
And, can the DoS also be turned off? We want to use it for DANTE, and the PTP-Packets are coming really fast. So maybe the switch thinks thats a DoS-Attack...
- JohnRoNETGEAR Employee Retired
Hello Machtl,
Welcome to the community!
The firmware version 1.4.0.6 has an added feature to allow you to enable/disable power saving mode. DoS protection is automatic, I don't see a way to disable this on the switch. There are also some models (GS716Tv3, GS724Tv4, and GS724Tv5) which totally support disabling and enabling Sleep (Auto-power-down) Mode and EEE mode.
I hope this helps. Let us know if you have more questions.
Thanks,
- Machtl2Aspirant
ok, but disables this "power saving mode" also EEE on the switch? its a little unclear what "power saving mode" means...
thx!
