BurrtIceCream
Jul 31, 2016Aspirant
GS108Ev3 and Uverse NVG599 compatability
Anybody have experience with how to get this switch to see the internet? ATT says no switches behind the gateway are allowed. I just cannot believe that. I searched and searched and found some comments that this switch would work. But no. I had to disable my firewall on the client PC just to be able to access the switch. Now I can access it with both the ProSafe and via browser, but the gateway won't let it through. Any ideas?
Thanks in advance
Hi BurrtIceCream,
I am glad that you were able to figure it out and resolved the problem. :)
Since the problem has been sorted out, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi BurrtIceCream,
Welcome to the community! :)
Kindly answer the questions below:
a. Make sure that the GS108Ev3 switch is connected to the Uverse NVG599 then connect a PC directly to the GS108Ev3 switch. Are you able to get replies when you ping a website like google.com through the GS108Ev3 switch?
b. Are you getting a valid IP address on the PC while its connected to the GS108Ev3 switch?
c. Are you able to get replies when you ping the LAN IP address of the Uverse NVG599 (which is the default gateway) on a PC that is directly to the GS108Ev3 switch?
d. Are you using the GS108Ev3 just like an unmanaged switch?
e. What is the current firmware of the GS108Ev3 switch?
I look forward to your response.
DaneANETGEAR Community Team
- BurrtIceCreamAspirant
Hello, here are your answers.
1) No, I cannot ping websites. Response is "ping request could not find host www.google.com. Please check the name and try again."
2) Running ipconfig dispays a valid IPv4 address
3) Yes, when I directly connect a Cat 5 cable from the PC to the NVG599 I can ping and get a response from the Uverse LAN IP (192.168.1.254)
4) The question is hard to answer. Out of the box, the Prosafe Utility could not find the switch, even if it was directly connected to the PC and no wireless adapter involved (Desktop unit with USB Wireless Adapter unplugged). I had to disable the firewall, understandable. However, after a refresh, I would get an error stating that the switch and Manager IP address are not in the same subnet. This caused me to disable DHCP and assign the right number in the third octet. (0 to 1) for both the IP address and the Gateway address. That would allow me access to the switch if I wanted to make a configuration change. Then I connected the switch to the Uverse Gateway and the PC. When performing a refresh in Prosafe, I get an error saying that it cannot access the Netgear Registration server. That tells me it cannot get past the gateway. I updated the firmware to 2.00.08 from 2.00.07 just to see if that would solve the problem. But to no avail. I can ping the PC and the Uverse gateway, but thats it. Using a browser I can access the Uverse configuration page through the switch, however I have no idea what to do there. I am not that network savvy. Something tells me the issue relies with the Gateway configuration, but I don't know that for sure. Inside the Uverse confiruation menus I see a Home Network Tab, and under that there is a Subnet and DHCP Submenu. In there I see an option for Cascaded Routers and currently that is disabled. That is why I think it might be the Gateway, but wanted to ask you first.
5) Orginally the F/W was 2.00.07, but now it is 2.00.08.
I have a second GS108Ev3 that I purchased at the same time, and it gives me the same issues.
All I am wanting to do is use the two switches to hardwire two pc's and all my entertainment equipment in several locations of my home, since the Gateway only has four ports. I just like the security of hardwire/hardware instead of using wireless for internet access.
I hope this helps.
Thanks for the prompt response Dane!
Hi BurrtIceCream,
Here are my follow-up questions:
a. On question C from my previous response, the setup that I am referring to is Uverse NVG599--GS108Ev3--PC. Are you able to get replies when you ping the LAN IP address of the Uverse NVG599 (which is the default gateway) on this setup?
b. Did you perform a factory reset on the GS108Ev3 switch after upgrading the firmware to v2.00.08? If not yet, it is recommended to do a factory reset on the GS108Ev3 switch after a successful firmware upgrade then reconfigure the settings from scratch.
c. From question A, you mentioned that you were not able to ping a website. Regarding this, have you tried to set a static DNS on the PC like 8.8.8.8 or 4.2.2.2?
DaneA
- daltont2000Aspirant
The "switch and manager ip address are not in the same subnet" message can be resolved as per Netgear manual in the following way:
Diagnostics and Troubleshooting71ProSAFE 8-Port and 16-Port Gigabit Click SwitchThe Switch Information screen displays.6.SelectSystem > Monitoring > Cable Tester.7.Select one or more check boxes.8.Click theTest Selected Portbutton.The switch tests the cable connection for the selected port and displays the results.Resolve a Subnet Conflict to Access the SwitchIf you power on the switch before you connect it to a network that includes a DHCP server,the switch uses its own default IP address of 192.168.0.239. This subnet might be differentfrom the subnet used in your network. You might see the following message if you try to usethe ProSAFE utility to access the switch:The switch and manager IP address are not in the same subnet.To fix this subnet conflict:1.Disconnect the Ethernet cable between the switch and your network.2.Unplug the switch’s power cord.3.Reconnect the Ethernet cable between the switch and your network.4.Plug the switch’s power cord into an electrical outlet.The switch powers on. The network DCHP server discovers the switch and assigns it anIP address that is in the correct subnet for the network."
- Apr 12, 2023Retired_Member
