kenargo
Aug 20, 2022Aspirant
GS308E-Editing the 802.1Q VLAN and add/remove VLAN ID's results in ALL VLAN ID's being broken
I noticed that if I edit the VLAN IDs in my GS208E the router destroys all programming for existing VLAN IDs. This has happened EVERYTIME I have needed to update the VLAN IDs. Every time I end up ...
kenargo
Aug 22, 2022Aspirant
See above:
Port 1 is the internet from my router and is tagged on all but ID=1. Ports 5 and 6 connect the primary router to the access points as tagged ports).
Ports 2 and 3 (ID=2010) are a NAS's bound interface (untagged)
if I try to add or delete a VLAN-ID, the web interface trashes the settings. Sometimes I get garbage characters, but nearly all the time the switch locks up and I cannot connect to it. If I factory reset the switch and enter things in order (add all the IDs, then membership) then everything goes well. An edit after the fact, not good.
JeraldM
Aug 24, 2022NETGEAR Employee Retired
Hi kenargo,
The configuration seems to be fine. By any chance, have you tried a different browser as well to see if it's the same issue?
JeraldM
NETGEAR Community Team
- kenargoAug 24, 2022Aspirant
I likely would have but I don't remember and (honestly) don't want to try as an edit operation usually trashes the whole configuration and needs to be followed by a factory reset in order to get the switch back online.
If I do need to make an edit, I'll try a different browser and screen-record the operation.
