dawntec
Nov 04, 2016Follower
GS728TP PoE OtherFault
HI, exactly the same error like this post: https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS728TP-PoE-Fault/m-p/474968#M1034 https://community.netgear.com/t5/Smart-Plus-Click-Swi...
Evans-o
Nov 08, 2016NETGEAR Expert
Hi dawntec,
Welcome to NETGEAR's online community.
For the Ports <=13, after the firmware upgrade, did you try to cxheck if the Admin Mode was set to "Enable"?
System > PoE >Advanced > PoE Port Configuration.
I suggest that after a factory reset or firmware upgrade and before you connect devices that are not needed for configuration to it, try to follow the PoE configuration steps starting on page 44 of the Software Admin manua here: http://www.downloads.netgear.com/files/GDC/GS728TP/GS752TP_GS728TP_GS728TPP_SWA_3Dec2013.pdf?cid=wmt_netgear_organic
Later, determine the port that will not need PoE devices, and disable PoE on them, then connect your devices and see if it works.
Also please send us screenshots of the erros when you can.
Please try and let us know.
