dawntec
Nov 04, 2016Follower
GS728TP PoE OtherFault
HI, exactly the same error like this post: https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS728TP-PoE-Fault/m-p/474968#M1034 https://community.netgear.com/t5/Smart-Plus-Click-Swi...
Retired_Member
May 26, 2017Hi dawntec,
We checked the configuration and log file, most likely there has a error about PoE driver, would you like to file a online support case? http://www.netgear.com/support/
