pgc's avatar
pgc
GSM7212P Firmware upgrade
Looks like there might be more than one version of this switch, but not sure how to tell what I have. Serial number is 2TH11952F0033
Current firmware is 9.0.2.18 can I upgrade to 10.0.2.20?
When I try the upload of stk file works ok, but on reboot it is still on the same version
thanks
  • Check the dual image status under Maintenance and look at "next active".
    • pgc's avatar
      pgc
      Thanks for your reply, swapped the acitive next boot round and problem solved
ProSupport for Business
