CTDhelpdesk
Feb 21, 2018Follower
GSM7248 Cannot factory reset
I've inherited a GSM 7248 and am trying to complete a simple factory reset. I've tried: 1) Holding the Reset button down for 2-3 seconds, per https://kb.netgear.com/24679/How-do-I-reset-a-smart-...
JohnC_V
Feb 22, 2018NETGEAR Employee Retired
Hi CTDhelpdesk,
Welcome to our community!
This kind of switches can only be set to factory default via CLI. You can access the CLI by using a direct console connection or by using a telnet or SSH connection from a remote management host. For the initial connection, you must use a direct connection to the console port. You cannot access the system remotely until the system has an IP address and subnet mask. You can set the network configuration information manually, or you can configure the system to accept these settings from a BOOTP or DHCP server on your network. Go into the boot menu and erase the configuration.
You may check the installation guide here.
