JMKIRK
Sep 01, 2017Aspirant
GSM7324 Factory Reset
I have obtained a used GSM7324 for some lab work and need to reset to factory default. I have followed some guides power down ... reset button for 10secs.....power on power down ... reset button f...
Hopchen
Sep 01, 2017Prodigy
Hi,
Fully managed switches, such as yours, can only be factory reset from:
1. The GUI
or
2. The CLI (via console)
The "Reset" button is just a reboot so it won't do much. If you do not know the IP of the switch, i.e. you cannot get to the GUI - then you need to aquire a console cable.
Cheers
