rmolinari69's avatar
rmolinari69
GSM7328Sv2 Stack member Status is not present
Hi,
I'm new in nthis community.
My problem is this.
I have 2 GSM7328Sv2 switch stacking mode.
Id Unit 1 is in the management status and unit id 2 is in stackmember status.
In recent days the unit id 2 goes fault, and the status of the switch is shown as "Not Present".
In the Monitoring-> Logs-> Buffered Logs see the following message:
<14> FEB 21 08:41:38 172.22.247.31-1 UNKN[102142592]: isdp_txrx.c(154) 4792 %% Foreign pdu on interface 13
How do I determine which is the problem of the fault status ?
Thanks for your help.
Riccardo.
  • Hi Rmolinari69,
    Welcome to NETGEAR community! :smileyhappy:
    Could you please follow belows checkpoint to diagnosis:
    1. Which version running on GSM7328Sv2?
    2. Which fiber module link between Unit 1 and Unit 2?
    3. Does the fiber module link up now?
    4. Please collect the stack information from command line interface as below:(you can login switch through telnet and input belows commands)
    show switch
    show stack-port
    show stack-port diag
    show stack-port counters
    show eventlog
    Please send the echo message from switch to us  after you input above commands.
    You can also send me a private message about echo message If any privacy you want to keep. :smileyhappy:
    • rmolinari69's avatar
      rmolinari69
      Hi Daniel,
      1. my version running on GSM7328Sv2 IS v1
      2. The fiber module link between unit 1 and 2 is AX742
      3. The front panel leds on the stack master switch (unit id 1) show a green light on Power, Fan, RPS, Stacl Master M1 and M2 Led
          The front panel leds on the stack member switch (unit id 2) show a green light on Power, Fan and M1 Led (not M2 Led)
      4. This are the output of your telnet  command line:
      (GSM7328Sv2) >show switch
      Management Standby Preconfig Plugged-in Switch Code
      SW Switch Status Model ID Model ID Status Version
      1 Stack Mbr Oper Stby GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
      2 Mgmt Sw GSM7328Sv2 GSM7328Sv2 OK 8.0.0.25
      (GSM7328Sv2) >show stack-port
      % Invalid input detected at '^' marker.
      (GSM7328Sv2) >show stack-port diag
      (GSM7328Sv2) >show eventlog
      Thank you.
      • DanielZhang's avatar
        DanielZhang
        NETGEAR Expert
        Hi Rmolinari69,
        Please enter the "enable" mode before you input these commands.
        Such as:
        1.Login DUT.
        2.Input Username and password.
        3.input enable and then enter
        such as:
        User:admin
        Password:
        (GSM7328Sv2) >enable
        (GSM7328Sv2) #show port all
  • Thanks Daniel.
    How I can disconnect faulty switch by stacking to put it in maintenance?
    Thanks.
      DanielZhang
      NETGEAR Expert
      Hi Rmolinari,
      Did it mean that you want to separate the Unit 2 from the stack?
      Then put it to maintenance about clean dust or RMA?
      It will make these two GSM7328Sv2 switch work as standalone mode after disconnect stack link.
      I suggest you to backup configuration for stack before next operation.
      You can remove the cable on AX742 between two unit then wait for  a minute.
      The stack will separate to two standalone GSM7328Sv2 .
      It's no need to remove AX742 module of GSM7328Sv2.
      Clean the dust may do some help for unit 2 just as you said.
        rmolinari69
        Hello Daniel,
        I found a third GSM7328S (serial: 1J867C5D00132) switch with the firmware version 8.0.3.15.
        How I do replace this switch with the unit id 2 switch in staching configuration ?
        When I disconnect the link cable that ip address take 2 switches(management and stackmember)?.
        After disconnecting the cable link I can bring the configuration of the second swtich on the third switch, install the AX742 module on the new switch and reconnect the link cable ?
        Thanks.
ProSupport for Business
