khagberg
May 31, 2016Tutor
GSM7352Sv2 bricked? No GUI or CLI access.
Adopting this switch was my foray into the world of enterprise networking. The switch was working, though I was having connectivity issues (which turns out was unrelated), upon which I noticed the fi...
- Jun 01, 2016
Hello khagberg,
Welcome to the community!
It appears that the flash memory may have been corrupted. I'm not sure if this recovery procedure from before will work because it needs at least a message displayed on the console. Is there a way you can test a different console cable?
Thanks,
JohnRo
Jun 01, 2016NETGEAR Employee Retired
Hello khagberg,
Thanks,
khagberg
Jun 04, 2016Tutor
In the end it was the cable causing the issue. I just bit the bullet and ordered another. New one arrived today and works like a charm. Now to reflash.
