htagawa
Nov 14, 2022Tutor
I cannot access over https on OSver 12.0.17.9
I recently updated my M4300 from version 12.0.15.4 to version 12.0.17.9. When I did so, I confirmed that I could no longer connect via HTTPS. Before the work was done, http was disabled and https wa...
InformaticaCOG
Jan 17, 2023Aspirant
We also have the same problem and can't find the way to access the Web GUI via https even with firmware upgrade 12.0.17.10 (we have updated it from version 12.0.15.7).
Is this a recognized bug by Netgear? Are they working in solving it? Is there any workaround?
Thanks in advance.
htagawa
Jan 17, 2023Tutor
I seem this is NeatGear side Bug.
Does your switch have accessibility via telnet or SSH?
this Bug is not accessible to WebUI via https. if http is disable on your swithc, then I think there is no way to connect your switch via webui.
I connect via SSH to the switch in this situation as workaround.
And if you will accept to connect without encryption, I think that is good to configure "ip http server" via SSH or telnet and be able to access the webui via http.
