Drekko
Jun 25, 2017Aspirant
JGS516PE during hot days
Hey guys Im wanting to buy a POE switch. I want to store it in a mounted switch cabinet in my garage. As I dont have much spare space inside The problem though is the garage gets pretty hot in s...
XavierLL
Jun 25, 2017NETGEAR Employee Retired
Hi Drekko,
Welcome to our community!
The JGS516PE has been designed to operate at a maximum of 50C degrees celsius, see below the datasheet:
http://www.downloads.netgear.com/files/GDC/datasheet/en/ProSAFE_Web_Managed_Switches_DS.pdf
Considering your environment adding exhaust fans to your cabinet definetly will help, moreover please consider improving your air flow in your garage to stay below the 50C.
Hope it Helps!
Xavier Lleixa
NETGEAR CBU PLM
Drekko
Thanks very much
for some reason I thought it was 0 to 40 degrees C?
I definently read that somewhere..
What happens if the room is 55 degress? :)
