sndlt
Jul 30, 2015Aspirant
LLDP on ProSafe GSM7248
Has anyone have much luck enabling LLDP on ProSafe GSM 7248 class managed switches? Below are my attempts (GSM7248) (Config)#ll? (GSM7248) (Config)# (GSM7248) >ena Password: (GSM7248) #...
JohnRo
Jul 30, 2015NETGEAR Employee Retired
Hello sndlt,
Welcome to the community!
I would like to know if you have tried to configure LLDP using the web interface of the swicth. Please refer to the image below for reference:
For configuring LLDP uisng the web ui, please click this link. You should be able to find LLDP global configuration of pages 104 up to 166 for LLDP-MED.
I hope using the web UI will help you with the configuration. I'll be looking forward to your response.
Thanks,
- sndltJul 30, 2015Aspirant
Thank you. I'll try that tomorrow when I get to office.
So this means I have to give interface(mgmt) an ip to access?
- JohnRoJul 31, 2015NETGEAR Employee Retired
Hello sndlt,
Yes, you'll have to give it an IP address for web access. You can follow this old version of the install guide found on our product support page, the document is a bit old but still applies.
I'll look forward to your response.
Thanks,
- sndltAug 02, 2015Aspirant
Having trouble getting a private IP from the department that manages IP addresses.
Is it possible to set a point-to-point straight layer 3 interface between a netgear port and my PC?
After that, I would get rid of the lay 3 interface in switch.
Would that disable LLDP once it's been activated?
Thanks!
