sndlt
Jul 30, 2015Aspirant
LLDP on ProSafe GSM7248
Has anyone have much luck enabling LLDP on ProSafe GSM 7248 class managed switches? Below are my attempts (GSM7248) (Config)#ll? (GSM7248) (Config)# (GSM7248) >ena Password: (GSM7248) #...
sndlt
Thank you. I'll try that tomorrow when I get to office.
So this means I have to give interface(mgmt) an ip to access?
JohnRo
Jul 31, 2015NETGEAR Employee Retired
Hello sndlt,
Yes, you'll have to give it an IP address for web access. You can follow this old version of the install guide found on our product support page, the document is a bit old but still applies.
I'll look forward to your response.
Thanks,
- sndltAug 02, 2015Aspirant
Having trouble getting a private IP from the department that manages IP addresses.
Is it possible to set a point-to-point straight layer 3 interface between a netgear port and my PC?
After that, I would get rid of the lay 3 interface in switch.
Would that disable LLDP once it's been activated?
Thanks!
