Eloge
Nov 03, 2015Aspirant
M4100-12GF compatibility with Mikrotik SFP Transceiver 1.5G 1310nm SM
Hi all, can someone confirm if M4100-12GF Netgear Switch compatible with Mikrotik SFP Transeiver 1.5G 1310nm Single Mode. I have already a cisco core switch which is using same Mikrotik SFP Transcei...
Eloge
I have Mikrotik S-31DLC20D SFP Module.
If not, could I link this module on Mikrotik Switch to an AGM732F Netgear SFP module plugged into Netgear Switch.
Thank you for your assistance.
Eloge
Jedi_Exile
Nov 04, 2015NETGEAR Expert
Considering they both comply with 1310nm single mode, it should work fine. You can use AGM732F on both sides or you can use S-31DLC20D on both sides or mix and match. If you want to be sure, you can match the spec data between the 2..
http://www.downloads.netgear.com/files/AGM732F_moduledoc_20Nov08.pdf
http://i.mt.lv/routerboard/files/SFP2-131002143557.pdf
- JohnRoNov 04, 2015NETGEAR Employee Retired
Hello Eloge,
I agree to Jedi_Exile, but I will still suggest the AGM732F since I know that it is compatible and has undergone a lot of testing.
Thanks,
