exocomp
Jan 29, 2017Aspirant
M4100-26G changes VLAN membership after reboot
Hi there, hoping someone can help or confirm this is an issue. I recently got my first M4100-26G and updated to the latest firmware 10.0.2.20, the unit and features work as expected however when I s...
LaurentMa
Jan 29, 2017NETGEAR Expert
Hi exocomp
Welcome to the Community!
I can confirm we don't show outstanding issues with firmware 10.0.2.20.
It is normal the time resets back to the default when you reboot, only SNTP time servers and time zone configuration are kept in startup-config, not the latest time before reset. After reboot, SNTP sync will happen and your M4100-26G will show correct time again.
Ports VLAN configuration should be kept intact after a reboot, provided the configuration was saved. Are you sure you actually save the configuration (so basically write the running-config into startup-config)? Are you using Web interface (GUI) or the command line (CLI)?
- Web GUI: Please refer to the M4100 Web User Manual page 14, table 1. On each page, there is a button APPLY. This APPLY button sends the updated configuration to the switch. Configuration changes take effect immediately, but in fact you are writing into the running-config. Running-config is volatile until you SAVE it into startup-config. To do that, please refer to page 405 and select Maintenance -> Save Config -> Save Configuration.
- CLI: Please refer to the M4100 CLI Manual page 371. The command save will permanently write running-config into NVRAM, in fact into the startup-config file.
(M4100) >enable
(M4100) #save
Let us know if this helps!
