exocomp
Jan 29, 2017Aspirant
M4100-26G changes VLAN membership after reboot
 Hi there, hoping someone can help or confirm this is an issue.  I recently got my first M4100-26G and updated to the latest firmware 10.0.2.20, the unit and features work as expected however when I s...
LaurentMa
Jan 31, 2017NETGEAR Expert
Yes right, Maintenance\Upload\HTTP File Upload\Text Configuration in order to let you download the configuration file, from the switch standpoint.
Thank you for your patience here, and your screenshots alongside text configuration show the issue you're having: there is conflicting port VLAN configuration on some ports. To me this is due to the fact you used Switching\VLAN\Advanced\VLAN Trunking Configuration for some configuration, and Switching\VLAN\Advanced\VLAN Membership or Switching\VLAN\Advanced\Port PVID Configuration for some other configuration. For instance on your Port 1, you said earlier you were seeing VLAN1 and VLAN50 added to the Trunk Allowed VLANs in Switching\VLAN\Advanced\VLAN Trunking Configuration after reboot. I think VLAN1 was back because VLAN1 was still kept as (default) Native VLAN in Switching\VLAN\Advanced\VLAN Trunking Configuration. If the port Native VLAN for untagged traffic is VLAN1, VLAN1 got to be added to the trunk. For VLAN50, although I can't see it in your previous screenshots, this was likely because of conflicting configuration at that time in Switching\VLAN\Advanced\VLAN Membership. Other example, I see conflicting utilization of Port PVID and Port Tagging for your port 7 (interface 0/7) in your configuration file.
I would recommend we only configure port VLANs "Access Ports, Trunk Ports and Native VLANs" in:
- Switching\VLAN\Advanced\VLAN Trunking Configuration
or, alternatively, not simultaneously, we configure ports VLANs "Untag modes, Tag modes and PVIDs" in:
- Switching\VLAN\Advanced\VLAN Membership, and Switching\VLAN\Advanced\Port PVID Configuration
The configuration file above has mixed up configurations, so we should restart from a clean sheet. Maybe you can perform a factory-default in Maintenance\Reset\Factory Default for this. Then only use one of these methods. One think to keep in mind: VLAN1 is enabled by default on all ports (Access Ports, or untagged mode), so it must be removed from trunks and other access ports when necessary.
Based on my understanding of what you want to achieve (please keep me honest here):
- Ports 1, 5 and 7 in trunk mode with only tagged VLANs 100,200,300 allowed and no native VLAN for untagged traffic
 - Ports 2, 3, 4 and 6 untouched (so in access mode with untagged VLAN 1)
 - Port 7 in access mode with untagged VLAN 50
Here's the configuration for both modes. Of course, you can use local console (CLI) as well.
interface 0/1 switchport mode trunk switchport trunk allowed vlan 100,200,300 exit interface 0/2 exit interface 0/3 switchport mode trunk switchport trunk allowed vlan 100,200,300 exit interface 0/4 exit interface 0/5 switchport mode trunk switchport trunk allowed vlan 100,200,300 exit interface 0/6 exit interface 0/7 switchport mode access
switchport access vlan 50 exit
interface 0/1 vlan participation exclude 1
vlan participation include 100,200,300 vlan tagging 100,200,300
vlan acceptframe vlanonly exit interface 0/2 exit interface 0/3 vlan participation exclude 1
vlan acceptframe vlanonly exit interface 0/4 exit interface 0/5 vlan participation exclude 1
vlan acceptframe vlanonly interface 0/6 exit interface 0/7 vlan pvid 50 vlan participation exclude 1
vlan participation include 50 exit
exocomp
Jan 31, 2017Aspirant
Hi Laurent,
You got most of my setup correct, except I needed interface 7 (VLAN 50) to be in general mode. I reset the switch to factory settings and did the configuration again using the web interface, I ran into an issue where if I set interface 7 (VLAN 50) in general mode it added VLAN 50 to the "Trunk Allowed VLANs" of the other interfaces. Confused but determined I reset everything to factory settings again and then proceeded to do everything on the CLI and this time everything worked as I wanted it and the settings were retained even after a reboot.
So my take away from this was to make changes using the CLI and use the Web Interface as read only mechanism which is fine by me.
Thanks for your support! So far I'm really impressed by what this switch offers.
J
