xtrem3
Nov 20, 2015Aspirant
M4100-26G Gateway issues
Hi guys,
It is not really a problem but some of "\is it possible\" question
Let me explain, (Also, i'm sorry for my english as my mothertung is french)
1- I have a Standard router connected to switch port 1 (Vlan1) (Read not supporting vlan)
Switch port 1 IP adress: 192.168.50.112 (For testing but will change)
Gateway and DNS :192.168.50.1 (And also my Standard router Lan IP Adress)
My Vlan2
IP: 192.168.254.1 / 24
DHCP server (from the switch dhcp pool)
Gateway/DNS: 192.168.50.1
Using static route on the standard router for getting outside
My question is:
Is there a way that i can use the ip adress 192.168.254.1 as a gateway adress and DNS server for my vlan2 or I will always have to use 192.168.50.1?
If i can do that, how can I proceed?
Thank you
Best regards,
Jean-Marc
1 Reply
- xtrem3Aspirant
Oups im sorry.
My gateway work using the same subnet as my vlan.
It's my DNS server that i would like to use vlan2 gateway and transfert the request to 192.168.50.1 but remains 192.168.254.1 in my dhcp..
thank you
