Budgie4
Oct 18, 2017Tutor
M4100-D12G Configuring VLANs with shared Internet access
My switch is a GSM5212 with v. 10.0.2.26, (B1.0.1.1) firmware. I am tryng to configure routing VLANs with shared internet access using the guide at :- https://kb.netgear.com/30818/How-to-configure-routing-VLANs-on-a-NETGEAR-managed-switch-with-shared-internet-access
I have followed the guide exactly and DHCP is working on all three VLANs but I am not able to configure the routing on my firewall and cannot be sure that I have the switch totally correct as I cannot ping the firewall from either of the VLANs not directly connected, even though the default route in the switch is set to the firewall port address.
I would be grateful if somebody could please help with diagnosis of my errors!!!
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance.
- JohnC_VNETGEAR Employee Retired
- Budgie4Tutor
Hi and thanks for the support. I have to leave this issue for a couple of days to work on something else. Can we leave the thread open please and I shall get back to you when I resume work on this problem.
Thanks again.
Hi Budgie4,
As per checking on your profile that your device has a lifetime phone and chat support. It might be better we can take advantage of that. I suggest you to open a chat / case online on NETGEAR support and please let them know that you need assistance on setting up VLAN routing on your switch.
