chfascik
Mar 09, 2017Tutor
M4100-D12G VLAN routing - ping VLAN1
Hi, I have simple lab network: Router, switch M4100, external DHCP server and 2 hosts. I try to setup 2 VLANs and intervlan routing. 1. set static routing on router (172.16.5.1): a)...
DaneA
Mar 09, 2017NETGEAR Employee Retired
Hi chfascik,
Kindly click on this article and it might help. Kindly use it as your guide.
DaneA
NETGEAR Community Team
- chfascikMar 12, 2017Tutor
DaneA wrote:Hi chfascik,
DaneA
DaneA I made exactly the same configuration as described in Your link.
Setup VLAN routing
Setup static routing
Setup default route
Setup DHCP server.
1. DCHP server (located in vlan 1) give IP addresses to all VLAN7 and VLAN8 clients.
2. I can ping from VLAN 1 to VLAN 7 and 8 VLAN interface and clients
3. I can ping from VLAN 7 to VLAN 8 VLAN interface and clients
4. I can ping from VLAN 7 to VLAN 1 interface (172.16.5.254)
5. I can ping from VLAN 7 to router/gateway (172.16.5.1) located in VLAN 1
6. I can't ping any host conncted to VLAN 1 on switch.
7. I can ping from VLAN 7 WiFi clients connected to router (client addresses 172.16.5.x/24).
There is only problem with traffic from VLAN 7 and 8 to VLAN 1 clients connected to VLAN 1 on switch ports.
try to do that on M4100-d12g and M4100-26G. The same resault. :(
Sorry for forum spam but I solved the problem.
What was wrong? Gateway IP address on DHCP server for VLAN 1 and on all clients connected to switch to VLAN 1 ports. So I have to change Default Gateway for 172.16.5.x/24 network from 172.16.5.1 to 172.16.5.254 and now works fine.
thanks for You for Your help and directinons :)
- DaneAMar 13, 2017NETGEAR Employee Retired
On behalf of @Jedi_Exile, you're welcome :) I'm glad to know that you were able to solve the problem and thanks for sharing what you did to solve it. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
