chfascik
Mar 09, 2017Tutor
M4100-D12G VLAN routing - ping VLAN1
Hi, I have simple lab network: Router, switch M4100, external DHCP server and 2 hosts. I try to setup 2 VLANs and intervlan routing. 1. set static routing on router (172.16.5.1): a)...
chfascik
Mar 12, 2017Tutor
Sorry for forum spam but I solved the problem.
What was wrong? Gateway IP address on DHCP server for VLAN 1 and on all clients connected to switch to VLAN 1 ports. So I have to change Default Gateway for 172.16.5.x/24 network from 172.16.5.1 to 172.16.5.254 and now works fine.
thanks for You for Your help and directinons :)
DaneA
Mar 13, 2017NETGEAR Employee Retired
On behalf of @Jedi_Exile, you're welcome :) I'm glad to know that you were able to solve the problem and thanks for sharing what you did to solve it. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,
DaneA
NETGEAR Community Team
