nhickey
Oct 26, 2016Aspirant
M4100 managed switches in series - dropping connection briefly
Hi all,
Firstly, I'm totally new to this forum and have searched for my issue without success.. so apologies if this has been discussed before.
The problem...
I have an issue with a user using Skype at his home. He complains about calls being dropped and having brief disconnections from the internet. I have had the devices at his house on continuous ping, and have seen that they are not responding from time to time.. only a few pings dropped at a time (from 1 to 5; not necessarily all together).
Our setup:
There is a server room with an M4100 50G switch in it providing fibre connection to an M4100-D12G device approx. 250 meters away. This smaller switch then has another M4100-D12G connected via fibre again (150 meters this time). This second switch is close to the user’s house. We have three wires running into his house: one for his laptop (at his request) and two for two wireless access points installed at the house.
I don’t have any special configuration on the switches, other than and static IP and access for the two VLANs we are using (ports are set to trunk)
At the risk of sounding stupid (!), is there something I'm missing config wise? What reason would the switches have to drop connection between each other like this?!
Any help is most welcome!
Thanks,
Neil
- JohnRoNETGEAR Employee Retired
Hello nhickey,
Welcome to the community!
I believe it is best to try and isolate the issue first. Try running a traceroute or Wireshark and locate where the packets are being dropped. Also, it is best to make sure that the firmware versions of the devices are all updated.
Thanks,
- Anonymous
Hi nhichey,
I suggest you could check the port statistics at first, it can judge whether the port discard packet or not.
Login the Switch web GUI, go to 'Monitoring'-->'Ports'-->'Port Detailed Statistics', check the couter of 'Total Transmit Errors' and 'Total Transmit Packets Discarded'.
For further analysis, could you please provide the network topology and switch configuration.
Thanks,
Eric
NETGEAR® Community Team - nhickeyAspirant
Hi John / Erik,
Thanks for your replys.. they are much appreciated, and also excuse the delay getting back to you!
I have checked the port statistics as suggested. There are four ports in use, but they are all showing '0' for total transmit errors and total transmit packets discarded. When I try to ping the switch IP I get periodic breaks, so I figured that the uplink port (port 12 fibre port) would show an error, but it did not. Here is the statistics from the port, the stats were cleared in the last hour and a half, but the user has complained of drop out in that time period.. can you guys can see something I'm missing?:
Interface 0/12 MST ID CST ifIndex 12 Port Type Normal Port Channel ID Disable Port Role Designated STP Mode Enable STP State Forwarding Admin Mode Enable Flow Control Mode Disable LACP Mode Enable Physical Mode Auto Physical Status 1000 Mbps Link Status Link Up Link Trap Enable Packets RX and TX 64 Octets 78023 Packets RX and TX 65-127 Octets 114250 Packets RX and TX 128-255 Octets 38808 Packets RX and TX 256-511 Octets 27107 Packets RX and TX 512-1023 Octets 9823 Packets RX and TX 1024-1518 Octets 56225 Packets RX and TX 1519-2047 Octets 0 Packets RX and TX 2048-4095 Octets 0 Packets RX and TX 4096-9216 Octets 0 Octets Received 106342746 Packets Received 64 Octets 65226 Packets Received 65-127 Octets 65099 Packets Received 128-255 Octets 34937 Packets Received 256-511 Octets 22983 Packets Received 512-1023 Octets 7947 Packets Received 1024-1518 Octets 51359 Packets Received > 1518 Octets 9 Total Packets Received Without Errors 230492 Unicast Packets Received 82407 Multicast Packets Received 56898 Broadcast Packets Received 91187 Receive Packets Discarded 0 Total Packets Received with MAC Errors 14255 Jabbers Received 0 Fragments Received 200 Undersize Received 0 Alignment Errors 0 Rx FCS Errors 14055 Overruns 0 Total Received Packets Not Forwarded 9 802.3x Pause Frames Received 0 Unacceptable Frame Type 0 Total Packets Transmitted (Octets) 15104341 Packets Transmitted 64 Octets 12797 Packets Transmitted 65-127 Octets 49151 Packets Transmitted 128-255 Octets 3871 Packets Transmitted 256-511 Octets 4124 Packets Transmitted 512-1023 Octets 1876 Packets Transmitted 1024-1518 Octets 4866 Packets Transmitted > 1518 Octets 0 Maximum Frame Size 1518 Total Packets Transmitted Successfully 76685 Unicast Packets Transmitted 66702 Multicast Packets Transmitted 6101 Broadcast Packets Transmitted 3882 Transmit Packets Discarded 0 Total Transmit Errors 0 Total Transmit Packets Discarded 0 Single Collision Frames 0 Multiple Collision Frames 0 Excessive Collision Frames 0 STP BPDUs Received 0 STP BPDUs Transmitted 0 RSTP BPDUs Received 6 RSTP BPDUs Transmitted 2738 MSTP BPDUs Received 0 MSTP BPDUs Transmitted 0 802.3x Pause Frames Transmitted 0 GVRP PDUs Received 0 GVRP PDUs Transmitted 0 GVRP Failed Registrations 0 GMRP PDUs Received 0 GMRP PDUs Transmitted 0 GMRP Failed Registrations 0 EAPOL Frames Received 0 EAPOL Frames Transmitted 0 Time Since Counters Last Cleared 0 day 1 hr 31 min 47 sec Thanks So so much,
Neil
- Anonymous
Hi nhickey,
Thanks for your updating immediately.
I found that there is some 'Rx FCS Errors' in the port statistics. Which type fiber module you are using? Could you change another pair of fiber module and try again?
Thanks,
Eric
NETGEAR Employee- nhickeyAspirant
Hi Eric,
The SFP mudule we are using is a Netgear one.. here's a link:
Could there be a fault in the cable?? The trouble is, the cable connecting the two switches is under ground!
We have no spare SFP modules, and would need to get new ones. Would you recommend we do that?
Thanks,
Neil
