XanderVR
May 08, 2017Aspirant
M4300-24X24F VLAN's, ACL and separation
Good day all, I have found an article, but as soon as I try to set the rules according to the article I lose all connection to the switch and need to undo the ACL using the console cable... http...
Retired_Member
May 09, 2017Hi XanderVR,
Welcome to the community! ![]()
First, the Switch M4300 support binding ACL rule to VLAN port, please refer to below configure:
By CLI command:
By web GUI:
Second, I notice that only permit tcp protocol in your ACL rule. Do you only allow tcp packet between VLAN10 and VLAN20?
Hope it helps!
EricZ
NETGEAR employee
XanderVR
May 10, 2017Aspirant
Hello Eric,
thank you for the information, I will put this to test later today.
I knew that it was possible in the web interface, but I prefer CLI for configuring, and use the web interface for a visual view of settings.
I think TCP is sufficient, as the servers are all webservers which are connected to using HTTP, HTTPS or SSL, so all TCP.
Each VLAN has its own DHCP server so there won't be any UDP passthrough needed.
The rules I created are sufficient for blocking all VLAN taffice to VLAN1, which is not VLAN1 subnet? (Except for the small VLAN20 portion ofcourse)
- Retired_MemberMay 10, 2017
Hi XanderVR,
Yes, agree with you. The rules should meet your requirement, and the policy should binding to VLAN1 for outbound direction. You can try it on your network. And looking forward to your good news.
