mrpzy
May 29, 2018Tutor
M4300 and Mix Stacking
Hi Guys,
I have the M4300 12x12f switches and im trying to see if I can stack with other netgear switches.
Can anyone tell me if the following switches are stackable?
S3300-52X - I ...
mrpzy
May 30, 2018Tutor
Thank you for the quick reply @LuarentMa .
This is helpful information.
Would you be able to confirm what the best settings would be to connecting the m4300 top level switch to other non stackable switeches?
Thank you again.
Thank you again.
LaurentMa
May 30, 2018NETGEAR Expert
Sure, if M4300-12X12F as your core switch, it would be best practice to "distribute" your other standalone switches in a star topology. You could add a level of redundancy with a second M4300-12X12F at your core, in a stack. LACP connections across this stack from all other switches would be the way to go. May this diagram from M4300 datasheet inspire you:
M4300 applications
