montie_dj
Apr 21, 2020Aspirant
M4300 boot or firmware
Hello.
Sorry about my english and mistakes in words.
I have a swotch model m4300-8x8f. I buy used this dev. The is a problem with this switch. Switch not boot os.
In terminal i have that msg:
lots off errors
4 ecc_errors after reading e460800:0
4 ecc_errors after reading e6c0800:0
4 ecc_errors after reading eec0800:0
4 ecc_errors after reading f0a0800:0
4 ecc_errors after reading f880800:0
4 ecc_errors after reading fa60800:0
156 ecc_errors after reading 35e8800:0
60 ecc_errors after reading 3608800:0
8 ecc_errors after reading 3d61800:0
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xc875832e, read 0x2e fafce4
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 247:58016
UBIFS error (pid 0): ubifs_read_node: expected node type 1
UBIFS error (pid 0): do_readpage: cannot read page 181 of inode 96, error -117
Error reading file '/image2'
/image2 not found!
sometimes thereis a menu u-boot menu
ver=U-Boot 2012.10-00245-g79946b8c89 (Feb 21 2018 - 17:08:40)VerNo=1.0.0.11
Environment size: 2257/131068 bytes
m4300r2>
? - alias for 'help'
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootz - boot Linux zImage image from memory
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - boot image via network using DHCP/TFTP protocol
echo - echo args to console
env - environment handling commands
exit - exit script
false - do nothing, unsuccessfully
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
itest - return true/false on integer compare
license - print GPL license text
loadb - load binary file over serial line (kermit mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mdc - memory display cyclic
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mtdparts- define flash/nand partitions
mtest - simple RAM read/write test
mw - memory write (fill)
mwc - memory write cyclic
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ubi - ubi commands
ubifsload- load file from an UBIFS filesystem
ubifsls - list files in a directory
ubifsmount- mount UBIFS volume
ubifsumount- unmount UBIFS volume
validate- Validate the image
version - print monitor, compiler and linker version
How to revert this dev to orginal config? Unfortunately there isn't a menu (recovery menu). only u-boot menu.
Maybe the is sollution to boot switch from usb drive? jtag?
How to flash this dev?
- Retired_Member
Hi montie_dj
Welcome to Community!
Could you please login console port and input command 'reset' under m4300r2> mode? Then check if switch can bootup success or not.
If still not work, please input command 'setenv bootfile = image1', then do above operation again.
Hope it helps!
EricZ
- montie_djAspirant
Retired_Member
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xf7b297f5, read 0x18ff4c2b
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 241:102864
UBIFS error (pid 0): do_readpage: cannot read page 12 of inode 96, error -117
/image2 not found!
Bad FIT kernel image format!
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0x5014e6e3, read 0xe250c3bc
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 318:92912
UBIFS error (pid 0): do_readpage: cannot read page 18 of inode 95, error -117
Error reading file '/image1'
/image1 not found!
/image2 not found!
## Error: "tftp_boot" not defined
Hello.THx for email.
Unfortunately your solution its not working.
After reset i have the same erro, after write setenv - the same
