CrustySparks's avatar
Jan 16, 2018
M4300 trying to rest ip http port number to default port 80
Trying to reset the http port back to default 80 from 6535:
my startup-config ... partial ...
exit
ip http port 6535 <---
ip http secure-server
ip http secure-protocol TLS1
ip ssh server enable
CLI manual says:
no ip http port
Switch says:
(M4300-12X12F) (Config)#no ip http ?
                                                         accounting Configure an Accounting List.
                                                         authentication Configure an Authentication List.
(M4300-12X12F) #show version
Switch: 1
System Description............................. M4300-12X12F ProSAFE 12-port 10GBASE-T and 12-port 10G SFP+, 12.0.2.20, 1.0.0.9
Machine Model.................................. M4300-12X12F
Serial Number.................................. 4G43697E80107
Burned In MAC Address.......................... 10:DA:43:F9:47:91
Software Version............................... 12.0.2.20
CPLD version................................... 0x5
Bootcode Version............................... 1.0.0.9
Current Time................................... Jan 16 09:53:40 2018 (UTC-8:00)
Current SNTP Sync Status....................... Success
(M4300-12X12F) (Config)#show ip http
HTTP Mode (Unsecure)........................... Enabled
HTTP Port...................................... 6535
Maximum Allowable HTTP Sessions................ 16
HTTP Session Hard Timeout...................... 24 hours
HTTP Session Soft Timeout...................... 15 minutes
HTTP Mode (Secure)............................. Enabled
Secure Port.................................... 443
Secure Protocol Level(s)....................... TLS1 -----
Maximum Allowable HTTPS Sessions............... 16
HTTPS session hard timeout..................... 24 hours
HTTPS session soft timeout..................... 15 minutes
Certificate Present............................ True
Certificate Generation In Progress............. False
(M4300-12X12F) (Config)#show captive-portal
Administrative Mode............................ Disable
Operational Status............................. Disabled
Disable Reason................................. Administrator Disabled
CP IP Address.................................. 0.0.0.0
  • Hopchen's avatar
    Hopchen
    Jan 17, 2018
    Hi CrustySparks,
    The issue is that you are doing this from the global config mode. You need to do it from EXEC mode, not config mode :)
    As this:
    (M4300) >enable
    (M4300) #ip http server
    (M4300) #ip http port 80
    Cheers
  • schumaku's avatar
    schumaku
    Dunno why the documented "no ip http port" does not work, no switch at hand, try this:
    no ip http server
    ip http server
    ip http port 80
    • CrustySparks's avatar
      CrustySparks
      Tutor
      (M4300-12X12F) (Config)#no ip http server
      % Invalid input detected at '^' marker.
      • schumaku's avatar
        schumaku
        ...continue with the other commands, regardless...
ProSupport for Business
