WillieEverlearn
Nov 03, 2015Aspirant
M5300 dhcp helper address
Attempting to take an existing flat network and create vlans to improve performance. I will admit that I am inexperienced in this, but I have seen a similar setup using Cisco switching. My plan was...
- Nov 10, 2015
I contacted NetGear support and was able to work it out.
The tech made changes using the GUI that I was unable to figure out using the CLI.
Also, need to add a few static routes in my WatchGuard firewall
JohnRo
Nov 03, 2015NETGEAR Employee Retired
Hello WillieEverlearn,
Welcome to the community!
I understand you are looking for a way to relay DHCP request to your server, let me try to help you with this one. I believe what you need to do is to configure the DHCP server in dynamic mode, for instructions please click this link.
I hope this helps! if you have more questions the community is happy to help.
Thanks.
- WillieEverlearnNov 04, 2015Aspirant
Thank you for the reply, John.
Correct me if I am wrong, but the link seems to create a new DHCP pool on the netgear.
This is not what I want.
The Windows Server 2012r2 is the DHCP server and I want to direct vlan broadcasts to it.
In the cisco world, I would add an ip helper-address...is this possible?
- JohnRoNov 04, 2015NETGEAR Employee Retired
Hi WillieEverlearn,
Yes, you are correct. I might have misunderstood what you were looking for. I believe this is what will apply. Please click here (web UI configuration) and here (for CLI configuration).
Thanks,
- WillieEverlearnNov 05, 2015Aspirant
This article applies to the following managed switches and their respective firmware:
- M5300 - firmware version 10.0.0.x
I am running firmware 11.0.0.12
I have stumbled onto a ip helper-address comand and configured it for Any interface for my Windows DHCP server, but I am still not receiving an ip.
