WillieEverlearn
Nov 03, 2015Aspirant
M5300 dhcp helper address
Attempting to take an existing flat network and create vlans to improve performance. I will admit that I am inexperienced in this, but I have seen a similar setup using Cisco switching. My plan was...
- Nov 10, 2015
I contacted NetGear support and was able to work it out.
The tech made changes using the GUI that I was unable to figure out using the CLI.
Also, need to add a few static routes in my WatchGuard firewall
JohnRo
Nov 04, 2015NETGEAR Employee Retired
Hi WillieEverlearn,
Yes, you are correct. I might have misunderstood what you were looking for. I believe this is what will apply. Please click here (web UI configuration) and here (for CLI configuration).
Thanks,
WillieEverlearn
Nov 05, 2015Aspirant
This article applies to the following managed switches and their respective firmware:
- M5300 - firmware version 10.0.0.x
I am running firmware 11.0.0.12
I have stumbled onto a ip helper-address comand and configured it for Any interface for my Windows DHCP server, but I am still not receiving an ip.
- WillieEverlearnNov 10, 2015Aspirant
