jlusky
May 25, 2016Follower
Management IP after upgrade to 10.0.2.13
I just upgraded my M4100-50G-POE+ to firmware 10.0.2.13 (from 10.0.1.16). I was not using IP routing before, and my managment vlan is 1102 instead of the default vlan 1. After the upgrade, I am no longer able to change the management IP. The "network parms" command is still visible in show running-config, but it doesn't let me enter or remove the command from configuration mode. How do I get the switch back to a state where I can set the management IP, other than doing a factory default?
1 Reply
- Retired_MemberThe network parms was to configure the CPU interface. NETGEAR removed it (cf release notes).
Now, the management interface is really a VLAN interface.
As the command network parms has been removed, you can't do a no network parms.
Two solutions:
1) use ezconfig to set your management IP, it will remove the network parms
2) extract the config, remove the network parms line, clear config, reinject it, add an IP to vlan interface 1102
