krobinson's avatar
May 17, 2017
Multicast traffic only goes in one direction (need to send multi cast back)
We have a igmp layer 2 network for multicast video traffic. I am able to join multicast traffic in "one direction"
Source A and TV A ---> M5300-52G3 --> LAG --> GS752TS --> Source B and TV B
TV A can only join multicast traffic from Source A
While
TV B can joing mulitcast traffice from Source A and Source B
Why can TV A not joing anyting from Source B??
I have IGMP queier enabled on both switches:
  • Retired_Member's avatar
    Retired_Member
    Hi krobinson,
    Welcome to the community! Smiley Happy
    Could you please check whether enable IGMP Snooping in the VLAN or Interface both for TV A and TV B.
    As Switch will generate MFDB table and IGMP Group entities only when enable IGMP Snooping in the VLAN or Interface.
    Hope it helps!
    EricZ
    NETGEAR employee
    • krobinson's avatar
      krobinson
      Tutor
      Yes, IGMP snooping is enabled on all ports including the LAG.
      When I have querier enabled on both switches the M5300-52G3 enables "Multicast Router" (under the IGMP Snooping Section) on the LAG. This sends ALL the video down the lag (over 4gigs of data). I will get video breakup in this situration.
      I do notice that if I disable querier GS752TS and have TV B connect to a mulitcast from Source B, then TV A is able to connect to the same multicast but nothing else.
      How is MLD snooping different than IGMP snoopping?
        Retired_Member
        Hi krobinson,
        MLD Snooping function behavior is same as IGMP Snooping, just for IPv6/IPv4 protocol.
        Could you please provide configuration file to us for further analysis?
        How do I send configure files from my Managed Switch to NETGEAR community moderators?
        http://kb.netgear.com/app/answers/detail/a_id/31439
ProSupport for Business
