markewert
Feb 05, 2017Aspirant
Need Operational Code for XSM7224S
Hello,
I am troubleshooting a problem with our XSM7224S ProSAFE switches and seem to have made it worse. The switch was not able to save the running configuration over the startup configuration (the switch would simply hang - we even left it "saving" for three days in case it was simply taking an abnormally long time). And when we aborted the save attempt by resetting the switch, it rebooted with default configurations. In trying to troubleshoot this we noticed that we were getting an error about the backup image CRC not being valid. And the switch was booting off image 2. So I tried copying image 2 over image 1 in the Dual Boot Configuration and now when the switch resets we just get the boot menu with the following error: "operational code CRC is not valid you must load new code".
Unforunately we did not backup the operational code for the XSM7224S (and are not even sure how to do this). I have scoured the forums and Google and cannot find anywhere to download a new copy. Does anyone know where it can be found?
Thanks!
Hi DaneA,
Thanks for the welcome!
Unfortunately the firmware (.stk) didn't work. It turns out that I somehow wiped the operational code and per NetGear support the only way to get it back is to RMA the switch. So I have a new one arriving tomorrow. :) If anyone else runs into this issue with the XSM7224S, simply chat with Netgear support and they will help you out.
- DaneANETGEAR Employee Retired
Thanks for the update. I am glad that NETGEAR Support was able to help you with your concern by having the XSM7224S RMA'd. :)
Let us know if the replacement XSM7224S switch you will receive would work fine.
DaneA
NETGEAR Community Team
- markewertAspirant
Hi DaneA,
