aviator2010
Jul 31, 2024Aspirant
Need to do a factory reset on m4300 switch
Hi
I have the following problem with a switch :
U-Boot 2012.10-00258-g1c5018gfe9 (Jul 26 2019 - 11:22:39)VerNo=1.0.0.15
UBIFS error (pid 0): ubifs_get_sb: cannot open "ubi:fs", error -19
UBIFS error (pid 0): ubifs_mount: Error reading superblock on volume 'ubi:fs' er rno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Saving Environment to SPI Flash...
Usage:
Usage:
BOOTP broadcast 1
Abort
m4300ns> <INTERRUPT>
m4300ns> ?
? - alias for 'help'
base - print or set address offset
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootz - boot Linux zImage image from memory
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dhcp - boot image via network using DHCP/TFTP protocol
diag - perform board diagnostics
echo - echo args to console
env - environment handling commands
exit - exit script
false - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
go - start application at address 'addr'
help - print command description/usage
i2c - I2C sub-system
iminfo - print header information for application image
itest - return true/false on integer compar
Now can I recover this situation - I accidently deleted permanent storage when trying to clear the configuration. Any help appreciated.
- RennaDNETGEAR Moderator
Hi aviator2010,
Welcome to the NETGEAR Community! 🙂
I suggest to contact NETGEAR support team and open a case about your issue. I believe there is a way to recover the switch when the permanent storage has been deleted.
https://www.netgear.com/about/contact-us/
RennaD
NETGEAR Team- aviator2010Aspirant
Aman,
re. this question:
This is regarding your case 48430260
Could you please tell me what is the power LED indication you are getting on the switch while it is powered on?As you will see with the detail i provided, the system is powered on - it gets through a boot sequence of sorts as my captured screen information eludes to, what are you asking here in exactly to 'power lED indication' when the system is clearly on.
Hi aviator2010,
I see that you have already contacted support. For the case to progress, please provide update to it by logging in to https://my.netgear.com/ and go to Support tab.
RennaD
NETGEAR Team
